No sound.
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: No sound.
    Member accies's Avatar
    Nov 2008
    Default No sound.
    Hi,I've lost the sound on a few channels on my Zgemma H5. 2tc on virgin. Played about with Audio settings but no joy. Anyone had same problem fixed?
    Mar 2012
    Belfast - Northern Ireland
    There is an issue with Virmin at the minute, this seems to be affecting genuine customers too. Have a look on Twitter and the VM forums.
    Sent from my SM-G950F using Tapatalk
  3. The Following User Says Thank You to grahampaull For This Useful Post:
    accies (13th November, 2017)
    Nov 2008
    Thanks for that,it seems is the HD not Sd that's affected.
    Mar 2012
    Yeah, SS Main Events HD and Sky News HD has lost all sound, CH4 HD has audio description and movies HD has audio description too along with multiple others.
  6. The Following User Says Thank You to grahampaull For This Useful Post:
    accies (14th November, 2017)
    Nov 2008
    That's a relief thought me box was Donald .
  8. #6
    maca's Avatar
    Feb 2009
    liverpool
    You can do a fix your self it inloves getting the PIDS from your box for said channels and rewriting them in a channel editor. Or just wait for vermin to fix it.
  9. The Following User Says Thank You to maca For This Useful Post:
  10. #7
    DK Veteran loncell's Avatar
    Jun 2008
    Can you get the correct PID's from a subbed TeaVo ?
  11. #8
    maca's Avatar
    Feb 2009
    liverpool
    Not to sure mate but the ones to try are 109 109 131 or 141
  12. The Following User Says Thank You to maca For This Useful Post:
  13. #9
    DK Veteran lincsat's Avatar
    Jun 2008
    The latest ABM config files do have a patch for most HD channels. Update your ABM configs and run it again. If using OScam, make sure you're using oscam-latest
  14. The Following 2 Users Say Thank You to lincsat For This Useful Post:
    accies (14th November, 2017), joe516 (14th November, 2017)
  15. #10
    maca's Avatar
    Feb 2009
    liverpool
    For some reason not updating in the north west
  16. The Following User Says Thank You to maca For This Useful Post:
  17. #11
    Nov 2008
    It's not clearing in South East either?
  18. #12
    digicon's Avatar
    You need to be running a recent image for you to get the config file, there was an update to ABM only yesterday as well. if your running quite an old image you may well find yourself stuck
  19. The Following User Says Thank You to digicon For This Useful Post:
  20. #13
    Nov 2008
    Open ATV 6.0 is that new enough?
  21. #14
    digicon's Avatar
    Afraid not no longer supported you will need the latest up to date version you can install of 6.1 which is built Daily, so if you flash todays image you will have all the latest updates installed including the ones for ABM
  22. The Following User Says Thank You to digicon For This Useful Post:
  23. #15
    Mar 2012
    Is abm built into openatv 6.1?
    I currently use ipab but it seems I'll need to upgrade to take advantage.
