Results 1 to 4 of 4
    May 2017
    Default Caterpillar COMM ADAPTER III not responding
    When powered, light up all the lights. Most likely a corrupted Boot sector memory. How to restore the Boot sector ? Perhaps there is a Pinout of the diagnostic connector (f.e. JTAG)? Or the technology of restoring such problems? P.S. The processor of this device is AT91SAM9260, without internal FLASH (((
    DK Veteran jctech's Avatar
    Dec 2009
    just beyond the edge of reason
    Use Com adaptor III toolkit to reload the firmware, under the utilities tab in Cat ET
    May 2017
    Comm Adapter 3 Toolkit says that devise is not responding, respectively to flash impossible. But device Manager in my computer shows as a cat Comm adapter 3 (it is correctly). Windows 7 32bit. The adapter is connected via USB cable. Cat ET 2015B. The Comm Adapter 3 Toolkit V. 3 1.9.0.32
    DK Veteran Wristpin's Avatar
    Dec 2009
    Mine failed several years ago and I sent it back to cat for repair, I don't remember what it cost......
    You know those cables go bad from time to time, have you tried another set of cables?
    Dive Naked,
    Everything looks bigger underwater!
