Hi M8, did you disassembled the dash?
Try to remove neddle, swich ignition on, plug the neddle, swich off. Swich on again and test, If fails, you must to repair dump or do calibration with Enigma tool.
Regards.
Outlander gen3 4x4 2013
speedo goes to 40km/h after reconnected to power?
dont know the reason? Is some procedure for calibration?
it dose go from full needle 4 moves dow to 0 and then jumps to 40 (straight line) and its stays there.
Is this some code? To tell me something or is step of calibration?
please help
Regards.
Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
Yes dash was out, yes dump was edited for km correction.
you think there is the problem?
dont have Enigma tool just Digiprog 3 . Digi will do the job??
needle sits at 40 when powered on have you tried driving the vehicle does the needle work properly on the road ? i.e does it look as if it is starting at the 40 mark and registering up?
if so have you maybe removed the needle or knocked it position whilst apart.
as said above try removing needle and resetting it with ignition on but engine not running.
if all else fails and still a problem go back to beginning and put original dump back and try it and see if it resolves the problem .
it may be a simple motor/needle position error it may be more significant but you need to try all things.
some of these new vehicles need the needles removed to do reset of the motor which occurs as battery power is connected after they have been manually moved or removed.
Try disconnecting the battery (leave for a minute or two), then remove the needle, reconnect the battery and put on ignition or start, then reconnect the needle as closely to originally marked neutral position.
Had this exact problem with a new Vigo and this is what i did to fix.
Will do all those steps tomorrow.
what if i dont have orginal dump anymore, can someone help to get one knowing the car model?
If it is a NS cluster and if it is not a step motor, and if you removed the needles to do what you have to do, then probably you cause a damage to the internal mechanism. It is possible to repair, but it will be much easier to replace it with another one from other dash. Send a picture of the mechanical components on board for identification of the cluster type.
Here picture.problem only with speed needle. This morning its hiw it was on 40km/h and when I start to drive it's moving but from 40kmh . So 45kmh on dash is real 5kmh and so one.
will check what i was told yesterday and will upload news.
Very funny. I am suspecting the mechanism and you sent picture of connections.
Please send picture of the mechanism to identify it, or just confirm that it is a NS cluster.
Thenks for complement (im funny)
did send what have, also you can see the model.
Claster is in the car not on the table.
Will try find more pictures and thanks for help.
no need to worry just do step by step and it will be normal
1st disassemble the cluster and plug into car and ignition ON
2nd now remove peedometer needle to 0
3rd now power off ignition OFF
4th now again ignition ON and see where your speedometer needle
All set and works fine
Will do will.
But: if goes now from full to 0 and goes back to 40, then if i will move from 40 till 0 , I think it will get some force trying go lover and up again?
Do you understand what i wrote now it like has space to move now from 0 to 40 so will remove that gap from 40.
becouse it goes to zero when i turn off the engine but when is turn on engine or dash its jumps to 40. But we will try to day.
Step by step
defected (17th November, 2017)
Replace the mechanism. That is your problem.As i said it is possible to repair, but it
is complicated to explain. Just replace it.
