    Nov 2017
    Default 2009 chrysler town & country
    Hi. I have problem with c can line. Car sometimes von't start, abs, airbags, check engine lamps on . Fault codes is: u0001 can c bus, u0002 can c bus off performance. Fault codes are in engine, abs, airbags, gateway modules.
    Someone know's were problem?
    Thanks for help
    narkeleptk's Avatar
    May 2017
    USA
    unhook modules till you find the bad one.
    Check connections. No one will be able to say where its at with out diagnosing the car.
    Maybe start with ABS since is giving code.
    Nov 2017
    Evet, tüm bu modelleri denemelisiniz, ve can kabama kontrol edin
    Nov 2017
    Yes, you should try all these models, check the cable and
    Nov 2017
    Thanks for a reply. I unplug engine ecu and u0001 can c bus fault was possible to delete. When I get other used ecu and try it to change, I write the result.
    Its dificult to find ecu, because engine is 4.0l limited...
    Nov 2017
    It vas a bad steering angle sensor...
  7. The Following User Says Thank You to darius211 For This Useful Post:
    narkeleptk (29th November, 2017)
