l adapt all pcr2.1
posibile full clone the ecu / need special tool
Hi guys
Have some problems finding solution for my problem.
I unlocked this Simos PCR2.1 and did a read then wrote modified file. Everything worked great.
Long story short, water got into ECU and it is junk .
I now have used ECU with same part#
So I have eeprom read file (8kb) and read/modified file from old ECU
Can I write eeprom from old ecu to new with boot and then unlock and flash with old file via OBD ?
OR is the best option to plug in new ECU and transport the car to dealer where they pair new ecu to the car.
I am using Kess V2 for this.
l adapt all pcr2.1
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
Post eeprom dumps i can fix this
can u help me fix mine plzzz if i post the dumps ?? or if u could go on my post and reply would be good thanks
