Hi M8, crank&cam signals are perfect and timming is ok.
What fault codes did you read??
Regards.
Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
Hello friend,
camshaft and crankshaft sensors are working fine!
Does it start with starter fluid in intake?
if yes, your problem is fuel related (pressure regulator, fuel pump, injection valve fuse or ground)
if no, your problem is ignition related (spark plugs, ignition coil, ignition switch where the key is put in)
Best wishes
abdulsattar
