Results 1 to 9 of 9
    Default 1997 mercedes E class Immo full, need help..
    Hello DK,
    I tried to program a chip to a 1997 Mercedes yesterday. Took the HC05 chip off the board, read the data, put into Tango to make a chip... Noticed that all positions were full... In the past I have run into problems using a used key position.. tried position 1 and also position 8.. the car starts and then shuts off... Does anyone have the ability to make any of the key positions not used???
    Thanks in advance....
    szengen's Avatar
    Jan 2017
    GAMBIT............car-prog not testet
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
    Sorry... are you saying I should use GAMBIT??? haven't heard of that...
    lion0304's Avatar
    Oct 2014
    Gambit or TM100 work good for old Benz 7935 key
    Apr 2017
    Its there a light in the mirror RED and GREEN
    Verzonden vanaf mijn iPhone met Tapatalk
    Oct 2015
    You can prepare auto programming chips by avdi, miraclone... after that just insert the key in to ignition it will program by itself
    no lights in the mirror.. just a light in the radio bezel... Tried programming a key with AVDI, didn't work... Used Tango, didn't work... put the bin file into the AVDI dump tool and it virginized the file, all the key slots are not used now, but I don't know if it striped all the data from it... and if it did, how to I resync the immo to the DME.... Ah, fun with old mercs...
    Bulgaria
    try this file without transponder and report!
    b.r.
    Thank you Icogsm... I will write to chip and try tomorrow..
    Thanks again...
