Results 1 to 15 of 21
    Feb 2017
    suriname
    Default 013 z800 kawasaki
    hi
    does anyone what type of transponder is in this bike?
    customer lost his keys and i am trying to write new keys or it and what the pages on the key look like!
    thanks kind regards mehmet
    Feb 2017
    suriname
    anyone ? have any idea ?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    4d id62........
  4. The Following User Says Thank You to drugowaz For This Useful Post:
    mehmet becker (25th November, 2017)
    Feb 2017
    suriname
    hi can you maby take a look on witch of these files is the right one ?
    i tryresd with xprog tried 2 chip type as i can not read what chip it is but i got to different readings
    thank s kind regards mehmet
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Upload eeproms
  7. The Following User Says Thank You to drugowaz For This Useful Post:
    mehmet becker (9th December, 2017)
  8. #6
    Feb 2017
    suriname
    hi sorry i tought i uploaded them
    kind regards
  9. #7
    Feb 2017
    suriname
    anyone maby have a reset file for this ecu kawasaki z800 21175-0789 made in indoensia
    or does anyone know how to keydata is written in the bin file ???
    thanks and kind regards
  10. #8
    igorr's Avatar
    Aug 2010
    Quote Originally Posted by mehmet becker View Post
    I belive that in your ecu is 93c86
  11. The Following User Says Thank You to igorr For This Useful Post:
  12. #9
    rola1971's Avatar
    Jun 2014
    Dublin
    check eeprom 93c86
  13. The Following User Says Thank You to rola1971 For This Useful Post:
  14. #10
    Feb 2017
    suriname
    hi
    yes i checked i found ra86
    if read as 93c86 depending on the chip i get different bin files see attachments
    can you add for mee key data ?
    mehmet
  15. #11
    Feb 2017
    suriname
    checked the file ?
  16. #12
    rola1971's Avatar
    Jun 2014
    Dublin
    yes it is work file
  17. The Following User Says Thank You to rola1971 For This Useful Post:
    mehmet becker (12th December, 2017)
  18. #13
    Feb 2017
    suriname
    If you unzip there are 2 files i read
    Witch one is ghe good one?
    Can you als read out key data for me? Or add a key
    Thanks regards
  19. #14
    igorr's Avatar
    Aug 2010
    here are you
  20. The Following User Says Thank You to igorr For This Useful Post:
    mehmet becker (13th December, 2017)
  21. #15
    Feb 2017
    suriname
    Thanks but does anyone know how the key datat is written cause i only see 8 number ahould there not be 11 numbers or somthing?
    Thanks regards
