your ecu data
I've this Seat Leon yr 2008 with a corrupted cluster.
Can someone please help me calculate PIN code from ECU Bosch MED17 (tricore) so that I can adapt new (used) cluster.
Please find attached reading of the ECU with FGTech Galletto.
Thank you so much in advance.
BR,
PM.
your ecu data
6841707059 576F526B 57416E5453 596F55 526F6B69424152
Thank you so much!!!
The pin is the same as the one I've calculated.
But, when adapting it always gives me error. Not accepted...
Immo 4 pin shouldn't be 4 digits instead of 5?
Do you have any idea if it has waiting time? I've tried 4 minutes, 5 minutes and it always gives me "not accepted" or something like that...
That's why I decided to read ECU. To check pin code. I thought the pin I've calculated before was wrong...
Any ideas please?
Thank you.
psam (17th November, 2017)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
manual procedure smok
fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
Thank you all.
Problem solved.
