Results 1 to 15 of 16
    May 2017
    Espaņa
    Default Toyota Transmission Control Unit 89530-12210
    Hi all, i have a toyota transmission control unit with ref 89530-12210 with software damaged.
    It comes from another workshop, they try to code with Launch but they bricked unit, then, they bought another one (used) and try to code, and bricked too.
    I have readed 93c66 eprom from both units and are same code inside. I dont know if its normal, and individual code is stored in MCU or are wrong
    Can somebody upload a working eprom dump of this unit? or tell me how to repair?
    Thanks a lot!
  2. The Following User Says Thank You to hrmotorsport For This Useful Post:
    dt200 (12th October, 2022)
  3. #2
    May 2017
    Espaņa
    Hi all, i bought another unit, i readed 93c66 and upload if anyone need it its here
  4. The Following 2 Users Say Thank You to hrmotorsport For This Useful Post:
    Davidik (20th July, 2018), subas (3rd July, 2023)
  5. #3
    dimitar's Avatar
    Quote Originally Posted by hrmotorsport View Post
    Did you solve the problem with this eprom????
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  6. #4
    May 2017
    Espaņa
    I readed it from another unit. Problem is when try to code with launch fail then lost connection and leave eprom damaged, i think reprograming with this last file i could try to program another time but i wasnt try
    Enviado desde mi VTR-L09 mediante Tapatalk
  7. The Following User Says Thank You to hrmotorsport For This Useful Post:
  8. #5
    Oct 2017
    Moldova
    you can upload the file again ... the link does not work??!!
  9. #6
    May 2017
    Espaņa
    Send me pm tomorrow and upload
    Enviado desde mi ALP-L09 mediante Tapatalk
  10. The Following User Says Thank You to hrmotorsport For This Useful Post:
  11. #7
    Oct 2017
    Moldova
    So you will be able to share working content!? I will be very grateful. In no way I can send you a private message.
  12. #8
    May 2017
    Espaņa
    Hi, i have two files.
  13. The Following 6 Users Say Thank You to hrmotorsport For This Useful Post:
    Davidik (20th July, 2018), dt200 (12th October, 2022), dziongas (7th February, 2020), gregar (17th September, 2022), subas (3rd July, 2023), tamer1024 (16th January, 2019)
  14. #9
    Oct 2017
    Moldova
    Talking
    Thank you. I put a rating and thanks
  15. The Following User Says Thank You to Davidik For This Useful Post:
    hrmotorsport (20th July, 2018)
  16. #10
    Apr 2016
    holland
    wich car is it ?? do you have tango ? did you try handshake ??
  17. #11
    May 2017
    Espaņa
    Hi, its from corolla 2003 but i am not sure.
    Yes i have tango. Why?
  18. #12
    Sep 2022
    Spain
    Could you clarify from which ECU the firmware you posted? In the title of the topic, you indicated ECU 89530-12210, but in the uploaded files we see a different ECU number - 89530-12213.
  19. #13
    May 2017
    Espaņa
    Sorry but i cant remember, this post has 5 years..
  20. #14
    ricked's Avatar
    Apr 2016
    Europe
    to make a long story short, thy did try "relearn" the MMT with launch thats why your file is empty as you say but actually its in relearning mode
    the fact is that launch or what ever tool you use not does the relearn is that something (maybe) wrong with the transmission
    so if you are verry sure that you did all the work correct on MMT and it still does not relearn you put in a file from a "relearned" MMT TCM as last sollution to get the N back on dash
  21. The Following 3 Users Say Thank You to ricked For This Useful Post:
    dt200 (12th October, 2022), fuzz1 (20th September, 2022), gregar (26th September, 2022)
  22. #15
    fuzz1's Avatar
    Jul 2019
    Seems to make sense.
