Results 16 to 30 of 36
Thread: PSA remotes
  1. #16
    Aug 2015
    Quote Originally Posted by klesk1986 View Post
    Not true - for me works last time in peugeot 407 2005
    isn't every 407 can line?
    So keydiy don't work for non flip remotes, like old 307 or 206 ?
  2. #17
    Oct 2015
    Quote Originally Posted by dtip View Post
    I think no, because my obdstar x300 won't pull pin from this.
  3. #18
    Aug 2015
    don't have obdstar but it think it is BSI type depended, probably won't pull from Siemens or JC bsi and working on Valeos...
    So does anyone know if keydiy works on older non flip psa remotes?
  4. #19
    Jul 2016
    Default PSA remotes
    KEYDIY will tell you if the existing remote is ASK or FSK.
    You can visually determine how many buttons there are and whether the remote is 0523 or 0536.
    If you get these details right then KEYDIY shouldn’t cause many issues for you.
    Personally I haven’t used any of the Chinese versions but I have considered stocking the variations of these remotes as another option. Stock is good and some customers do ask for a key that looks like the existing so keep the good sources for these keys coming - it is appreciated
    Sent from Luke’s iPhone using Tapatalk
  5. #20
    auto techniek's Avatar
    Mar 2017
    Quote Originally Posted by Mason7773 View Post
    How can you see if it is 0523 or 0536?
  6. #21
    Jul 2014
    Sofia
    @dtip "So does anyone know if keydiy works on older non flip psa remotes?"
    It is not working on old 307,partner,406 which are K-line. Also for all 206 and 206+. Remote packets coding is different.
  7. The Following User Says Thank You to RFRemotes For This Useful Post:
    dtip (20th November, 2017)
  8. #22
    Mar 2017
    Here also problems with K-line cars and Keydiy. Ordered some chinese remotes to test.
    Last week cut key for 307 and programmed transponder. But Remote no way. waste of time and customer sent without key. Very disapointing.
  9. #23
    kronk92's Avatar
    Sep 2016
    France, paris
    me too 307 2004 didn't work waste a lot of time
  10. #24
    Aug 2015
    Quote Originally Posted by RFRemotes View Post
    damn, why there is so many programs for old keys in keydiy app then....
  11. #25
    Oct 2015
    Maybe problem is key sync after coding - some cars need several seconds to start remote work.
  12. #26
    Jul 2014
    Sofia
    Unfortunately it is not only the key sync, packets which remote sends are coded differently. I mean hopping code algorithm is different. Physically signals for 0/1 sent by remotes are the same on CAN and K-line cars. Both are manchester coded.
  13. #27
    newone's Avatar
    Oct 2016
    i have not try on those you mention but today citroen c3 2004 k-line programed on cr43 with keydiy multi worked perfect
  14. The Following User Says Thank You to newone For This Useful Post:
    parrot1964 (23rd November, 2017)
  15. #28
    Wirral
    Quote Originally Posted by auto techniek View Post
    how do you tell the difference between 523 and 536? I just try them.
  16. #29
    mikajna's Avatar
    Mar 2015
    My friend, keydiy now work with older cars with old two buttons remote 6554xx models...someone help them to crack it, they have all models A5,C7...etc Maybe not all working properly, but they fix it in newer updates
  17. #30
    Jul 2014
    Sofia
    Ok, I didn't knew that they fixed this long-term bug. Now maybe it's worth to buy their equipment.
