Results 1 to 5 of 5
    konop11138's Avatar
    Default Partner 2011 hdi fap reset with diagbox
    Partner 1.6 hdi 2011my, how to make reset or replace fap?
    i can not find this option in diagbox 7.62
    Ecu is edc17c10, all funktion for programing is available, replace fap no, in additive ecu is the same, not this option.
    Fap in measuring block is 100% full, i need remove fap but before i must reset fap value.
    Thanks for any help.
    Oct 2013
    Spain
    To indicate the landing of the fap liquid in a berlingo 2012, after trying many times I came out in the injection section, I do not know if it will serve as guidance.
  3. The Following User Says Thank You to pedriii For This Useful Post:
    konop11138 (20th November, 2017)
    Mar 2015
    UA
    Hi. Use PP2000 .
  5. The Following User Says Thank You to MVVL For This Useful Post:
  6. #4
    konop11138's Avatar
    PP2000 not work with EDC17c10, any idea?
    Additive liquid in fap is ok, 0mg, but soot in fap is 100%.
    Thanks for any help
    Mar 2015
    UA
    Try the PP2000 via Berlingo 2, manually select the engine. I did that. Or Launch.
