Results 1 to 7 of 7
    Jan 2016
    ROMANIA
    Default FRM3R E87 PL2 6135 9241002-01 need eep file please
    Hello, I need eep file for FRM3R E87 PL2 6135 9241002-01, SW 125000, HW 06 - someone was trying to repair this module already, I was able to read Dflash (I have two files, I do not know which one is good) and Pflash but the eep file is empty.
    marco70's Avatar
    May 2012
    Lawok
    You eeprom test and report.
  3. The Following 2 Users Say Thank You to marco70 For This Useful Post:
    mihai cristian (17th November, 2017), Tourist69 (22nd August, 2018)
    Jan 2016
    ROMANIA
    Quote Originally Posted by marco70 View Post
    Can you, please tell me if the Pflash and Dflash file is ok? Thanks for your help.
    marco70's Avatar
    May 2012
    Lawok
    d-flash do not go program eeprom
    create emulated eeprom partition
    p-flash ok
  6. The Following User Says Thank You to marco70 For This Useful Post:
  7. #5
    Jan 2016
    ROMANIA
    p-flash ok
    Thanks for your help, I will report tomorrow.
  8. #6
    audiopoint's Avatar
    Mar 2011
    MACEDONIA
    can someone repair dums
    FRM3R E70 6135 9241002-01, SW 125000, HW 06
  9. #7
    Jun 2010
    Europe
    That dump is very corrupt. Normally, about every fourth byte should start with 0xB0 but your file looks not at all like that. Also, it seems that the same pattern repeats over and over again.
    You could try to read the D-flash with a different tool, but since your P-flash looks quite normal, I suspect that something was done to this FRM before those dumps were made. If that is the case, your only option is to program a dump from a different car, for example the one above, and code the FRM correctly.
  10. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    audiopoint (23rd January, 2021)
