Results 1 to 4 of 4
    Oct 2014
    other side of Mars
    Default MERC W203 ECU SWAP/REPLACEMENT
    Hello Friends.
    Guys i need help on a merc W203 im working on. The original ECU for the car go burnt, the owner of the car bought another ECU with same part numbers but slight differences on PCBs, he had someone remove/swap the flash AM29F400BB from the burnt ECU into the replacement ECU car failed to start. key is working perfectly and ignition turns. I have read the EIS, ESL, and the 2 AM29F400BB and attached.
    Can someone help me match these files so the car starts.
    any help goes along way
    Mar 2015
    UA
    Hi. AM29F400BB - 256 kb ?
    Shmortz's Avatar
    in the middle of nowhere
    you must swap eeprom also, 95p08 maybe...
    what type of ECU?
    Sep 2015
    Botswana
    Quote Originally Posted by chizzy85 View Post
    Hello Friends.
    just swap the eeprom st sp08 and car will start or read sp08 from old ecu and write on new ecu then car will start
