Results 1 to 15 of 20
    Default Renault / Bosch 7 649 175 391 Code
    Hello.
    I have Renault by Bosch 7 649 175 391 28 115 5444R T F351
    With Calc - F351 = 4782
    Code 4782 not working.
    I typed code 2 times - now i have - wait 90 minutes.
    Please Help me.
    I read 95256
    and 95256 :-)
    irfa's Avatar
    Feb 2016
    also read NEC mcu
    http://help.martech.pl/node/40
  4. The Following 2 Users Say Thank You to irfa For This Useful Post:
    Decode Ghost (18th November, 2017), sanixmen (18th November, 2017)
    irfa's Avatar
    Feb 2016
    Quote Originally Posted by Kristof1 View Post
    Hello.
    Please Help me.
    I read 95256
    or wrıte serıal bosch number 815CM...............
  6. The Following 3 Users Say Thank You to irfa For This Useful Post:
    Decode Ghost (18th November, 2017), Kristof1 (21st November, 2017), orteov (30th November, 2022)
    I need schematic how to connect to NEC. Please. This ?? - 815 3410
  8. #6
    irfa's Avatar
    Feb 2016
    Wrıte serıal number 815CM............
  9. The Following User Says Thank You to irfa For This Useful Post:
  10. #7
    I have only this
  11. #8
    irfa's Avatar
    Feb 2016
    I have only this
    are you sure there is no other tag,this is not
  12. The Following 2 Users Say Thank You to irfa For This Useful Post:
  13. #9
    Apr 2017
    EU
    On the back of the radio, you have the sticker labeled Serial number BP91 .....
    and in what car do you have that radio so that's why the radio should not ask for a code
    IF I HELP Don`t forget to use Thanks button and reputation
    I give negative reputation for people who even a THANKS not give for received helps!!!
    New Users Don't PM me for radio codes or similar, you will not get any answer...
    BR foks025
  14. The Following User Says Thank You to foks025 For This Useful Post:
  15. #10
    Yes I found :-) Thanks foks025 :-)
  16. #11
    Apr 2017
    EU
    Yes I found :-)
    try ....5503
    In your file is saved Vin compare it is like in the car
    BR foks025
  17. The Following 3 Users Say Thank You to foks025 For This Useful Post:
    Decode Ghost (18th November, 2017), irfa (18th November, 2017), smoggy (21st November, 2017)
  18. #12
    I have to wait 90 minutes - where is error counter in 95256 ??
  19. #13
    Apr 2017
    EU
    You also have erased the vin, let me know
    BR foks025
  20. The Following 3 Users Say Thank You to foks025 For This Useful Post:
    Decode Ghost (18th November, 2017), Kristof1 (21st November, 2017), zani70 (22nd February, 2021)
  21. #14
    Thanks You foks025 !!!!
    Code: 5503 - Working perfectly.
    Regards.
  22. The Following User Says Thank You to Kristof1 For This Useful Post:
    foks025 (21st November, 2017)
  23. #15
    Regards.
