You need to Diagnose with a proper tool to find out
But more likely you need Airbag module as well from the same car where you got you other bits from
This module is normally behind the car stereos
hi dk
i have a 2012 toyota verso proxmity key. vehicle was bought as non runnner. i purchased a key, the ecu , and the pcm.now i get ignition on but no crank and security light flash. under live stream it does not look key is reg.
i have there is an immo code module this vehicle. does anyone know the location of this unit and what it looks like???
ihave tested remote starter with intelligent tester andthe vehicle cranks well. can someone recommmendaa way forward to finish up coding ??
it was sold as a complete set. i get no fault codes on ecu and entry&start no faults either. if i try to do registration of key it does not recongize transponder around start switch.i have done test and switch works fine. i do have the original set but no key for it. can these keys be reused? could i virginise dump ? or can key be added ?
put all original modules back, buy a new key reset certification ecu over obd then write new key over obd if you have such tools, if not do it via dump with vvdi2
you can also get a used smart key and try to reset it with vvdi2
MonSter911 (20th November, 2017)
Ok thanks for the advice. If i try d plug donar smart moduleand key can this be aligned to vehicle ?
yes it can be aligned to a vehicle via dump, may be there some other ways but I'm not aware.
post a dump of certification ecu, engine ecu and may be steering lock ecu and ID code ecu, somebody will do it for you.
you can try pin 4 and 13 trick may be it will work.
check the esl for sure its not synchronized with the kit if its not working read esl data and post all the data to pair it
Seems to have an electrical on pcm now. After resetting key and putting old modules back i get ignition but theres NOTHING coming on except the screen in the corner... i supply earth to one of the contacts and dash came on again then off. I suspect the plugs maybe damaged, so there is no communication from the power management control to ecu. PMC MODULE : 89690-0F030
Does anYONE have pinout for this ?
you'd have to dismantle the dash to find the immo. it's a small box-like thingy.
