hi test ok
pass in pm
hi test ok
pass in pm
Tariel (19th November, 2017)
Your cleared file, pass in pm.
Best regards.
Dragon
Tariel (20th November, 2017)
Describe errors ? Did you do calibration OCM ?
Best regards.
Dragon
1. B1319 - OCM ( current) . We try to calibrate if this scanner does
2. B1644 - without description (Hystory, clear but appears again )
Did you change bad elements ? Pretensioners, airbags ? Did you join resistors 2,2ohm or 3,3ohm for check and clear errors ?
Best regards.
Dragon
Check this variant, pass in pm.
Best regards.
Dragon
Ok. Old error :
dragon100
You first file is Ok, problem with airbag module connector . Thank you , good luck.
Brrr :-) .............
Best regards.
Dragon
