Results 1 to 3 of 3
    Mar 2016
    ireland
    Default mercedes vito speedo troubles
    hi dk like above I have a 2004 vito and when I drive I drive it the speedo works ok for mins then abs comes on and speedo stops working ... i read dtcs with autocom and get p549e incorrect rotor at one of the wheels , I know the speedo works off the n/side wheel so I checked the wiring back to the abs pump and it checked ok so I changed the abs sensor and wheel bearing on the n/s front still the same , but on live data while driving the n/s speed is double what the other 3 wheels are, am looking at an abs pump problem .... thanks in advance dk ...
    Nov 2009
    workshop
    check epc for compatible esp sensor
    and coding for ecu esp and eis with star diag
    Mar 2016
    ireland
    will check and let you know ,cheers
