    Cheshire, UK
    Smile BMW 5 series 2006 steering lock fault
    I have a 5 series bmw with a suspected steering lock fault. The customer has newly bought the vehicle and called me out with a non start fault . vehicle using a slot in column key . i noticed the steering lock was not engaged but could not get ignition . after a battery reset the vehicle started and operated as it should , steering lock engaging and disengaging for about 6 ignition cycles.
    the last time i removed the key the steering lock didn't engage and is back to square one again!!!! non start and no ignition
    If anybody has any images of how to remove or dismantle i would be very greatful
    My friend has ista that i can borrow, how would you programme a new steering lock without the ignition on ???
    I have done very little work with this system , is it similar to vw that gives you ignition when fitting new ignition lock to allow programming ????
    Is programming a s/h unit possible ???
    Thanks in advance for any advice given
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Try reset elv. If no help check ibs. If there good put emulator on elv
  3. The Following 2 Users Say Thank You to drugowaz For This Useful Post:
    AutoX4242 (20th November, 2017), rola1971 (20th November, 2017)
    Oct 2017
    BMW
    Delete ELV from flash - u are done !
  5. The Following User Says Thank You to TVO For This Useful Post:
  6. #4
    Cheshire, UK
    Quote Originally Posted by TVO View Post
    Do you delete it in the cas ??? can this be don vier obd or would i need to read flash and post dump???
    Oct 2017
    BMW
    Quote Originally Posted by AutoX4242 View Post
    What cas do u have ?
  8. #6
    Cheshire, UK
    its a cas 2
