program whit other bin not corrupted and immo off
I need a virgin dump for bsi of a Peugeot 307 2002
BSI is :
HW : 9636760580F
Product : 9644098180 variant C
SW : 9647648380
BSI was working since 15 years, but one day, the battery has run down, virginized the BSI, I was able to reprogram the BSI with PP2000, but I put the wrong PIN code, so the car didn't start anymore.
With one friend, we try to change the EEPROM but nothing worked. We change the PIN CODE inside, put all FF, put FF only on VIN and PIN, tried a lot of things but no luck, it is like the EEPROM is corrupted, I can do nothing in PP2000. I can't reprogram the BSI, it says "feature not available for your calculator", I put an IMMO OFF on my ECU but no luck.
Even my original dump look like corrupted because in PP2000, i have ?????? for my VIN and for my SW version, I did not have that when I reprogrammed the BSI for the first time.
So I need a good virgin EEPROM for this BSI.
Thanks you
I dont have bin not corrupted, bro
flash ori bsi 307
only flash i have
SORRY ERROR
tomorow i send files flash and eeprom 307.
just erase vin area in bsi with the programer and then just make bsi adaptation
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
edit deleted
Reality of life :
3:Everyone lies
I have it now, I asked it to a PSA dealer.
Reality of life :
3:Everyone lies
Reality of life :
3:Everyone lies
cedric33 (23rd November, 2017)
It is not the same variant, do you thinks it will work ?
