Today I've replaced pump module, there are two faults:
01318 - Control module for injection pump (J399)
03-10 - No signal - Intermittent
49-10 - No communication - Intermittent
I'm very very sorry to open a new thread, but in fear that nobody sees again my recently simillar open thread
It's for 2001 Audi A4 2.5tdi. My question is can I replace the following:
Original pump is: 059 130 106 H
I have fully working: 059 130 106 D
Can I mount 106D in place of 106H? If yes, I can only change pump module, or is must fully with mechanical part?
If not, what is the reason? I should change engine ECU, just engine ECU software..or?
This pump is coded.
you can not just exchange these.
The pumps, do they have the exact same partnumbers?
Tawe (26th November, 2017)
I've synced replacement pump as shown on RossTech instructions for pump swap (with 050 channel in adaptation). Just one thing that confuses me, I enter 09498 (pin code) as new value, after that I click on Test, and new value goes to 32000. Is it normal?
For pump numbers, I wrote in the first post that the pump's numbers are not the some, so I didn't know if they are interchangeable, or I should change also some other part.
Original pump: 059 130 106 H
Replacement: 059 130 106 D
I've repaired original (old) pump, car is working
