hello guy can someone please help me reduce milage on this Johnson bsi im not managing to this is a peuoet 307i eeprom is 95128 its is showing on dash 176186 and I ant to 90000 reason I change the bsi and recoded everything thank you
try this km....
Mr Mo (21st November, 2017)
here is your file
press button thanks
thank you guys I will check and report
guys i tried both files but non worked and vehicle doesn't start
try with the original dump and report back...
Mr Mo (22nd November, 2017)
dump chafik4051 = dump brend
thank you guys im gona try and report
Brend I write your dump car started but milage is 176186 can I not do it on the instrument cluster it has eeprom 95020 thank you all imafraid to use fvdi programer
follow panel and bsi test and thank
test.........
thank you friend
