Results 1 to 15 of 15
    Jan 2014
    Default please help johnson bsi milage
    hello guy can someone please help me reduce milage on this Johnson bsi im not managing to this is a peuoet 307i eeprom is 95128 its is showing on dash 176186 and I ant to 90000 reason I change the bsi and recoded everything thank you
    Jan 2014
    Default dash
    try this km....
  3. The Following User Says Thank You to chafik4051 For This Useful Post:
    Mr Mo (21st November, 2017)
    Mar 2016
    Argentina
    here is your file
    press button thanks
  5. The Following User Says Thank You to chris781 For This Useful Post:
  6. #4
    Jan 2014
    thank you guys I will check and report
  7. #5
    Jan 2014
    guys i tried both files but non worked and vehicle doesn't start
  8. #6
    Cllau's Avatar
    Mar 2017
    where friends need me
    try with the original dump and report back...
  9. The Following User Says Thank You to Cllau For This Useful Post:
    Mr Mo (22nd November, 2017)
  10. #7
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by Mr Mo View Post
    Press thanks+rep.
    If you damp good its work 100%
    ............90000.........
    NB!!! Don't ask in PM old file password , Im not remember.
  11. The Following User Says Thank You to brend For This Useful Post:
  12. #8
    Sep 2009
    dump chafik4051 = dump brend
  13. #9
    Jan 2014
    thank you guys im gona try and report
  14. #10
    Jan 2014
    Brend I write your dump car started but milage is 176186 can I not do it on the instrument cluster it has eeprom 95020 thank you all imafraid to use fvdi programer
  15. #11
    May 2012
    brasil
    follow panel and bsi test and thank
  16. The Following User Says Thank You to milmilhas For This Useful Post:
  17. #12
    May 2012
    brasil
    test.........
  18. #13
    Mar 2016
    Argentina
    this file is cluster
  19. The Following User Says Thank You to chris781 For This Useful Post:
  20. #14
    Jan 2014
    thank you friend
  21. #15
    Mar 2016
    Argentina
    thank you friend
    you welcome
