Results 1 to 15 of 20
    Top Poster + gpemporium's Avatar
    Feb 2016
    Davison, MI
    Default 2005 dodge ram stf9150 mileage correction
    Using a carprog - stf9150
    file provided is 168000 miles
    need 128500 miles
    any help will be thanked
    PM me for DASH files. Thanks are appreciated.
    May 2012
    brasil
    test plase
  3. The Following User Says Thank You to milmilhas For This Useful Post:
    gpemporium (21st November, 2017)
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    .........................................128500 mil ok
  5. The Following User Says Thank You to momogsm For This Useful Post:
  6. #4
    May 2012
    brasil
    Sorry, I misjudged
    momogsm correct
    Feb 2016
    Davison, MI
    tested - under the mileage I need but nearly spot on 125000.. thanks anyways
  8. #6
    May 2012
    brasil
  9. #7
    Feb 2016
    Davison, MI
    Quote Originally Posted by momogsm View Post
    this shows 168563 .... need 128500 miles
  10. #8
    May 2012
    brasil
  11. #9
    Feb 2016
    Davison, MI
    Quote Originally Posted by milmilhas View Post
    128500.......
    no change in mileage - 168563
  12. #10
    ascrap2003's Avatar
    Sep 2016
    Texas
    Algo should be KM / 13.185 = Décimal converted to Hex this is your bottom bytes then ad 1 to every set starting from top bytes down. This will put you within 20 miles
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  13. The Following User Says Thank You to ascrap2003 For This Useful Post:
  14. #11
    ascrap2003's Avatar
    Sep 2016
    Texas
    I’ll take a look later if you haven’t finished by then, if not showing correctly dump is corrupt .
  15. The Following User Says Thank You to ascrap2003 For This Useful Post:
  16. #12
    Feb 2016
    Davison, MI
    Quote Originally Posted by ascrap2003 View Post
    solved - thank you however - i would like to know the algo on these tho for future reference... feel free to private message me if you have any insight.. we settled with + 250 miles which is not good but passable.... please enlighten me if you have any info
  17. #13
    Feb 2016
    Davison, MI
    we tested a few files and this seems to be a very good algo. thank you very much
  18. #14
    ascrap2003's Avatar
    Sep 2016
    Texas
    I’m sure there’s a better way but this works for me, if not like said dump is corrupt. Are you connecting to legs or pads? I have a pic I’ll post up later for carprog
  19. #15
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Original Dump is ok, the other dumps posted here with 128.500 miles but spot on 125.000 miles are modifyed with Nyo, that is the problem.
