here.......
here.......
- Remember Don't Just Sit There In Boredom, Add to the Forum!!
dashtool2016 (21st November, 2017), zckariya70 (22nd November, 2017)
mark 0 km now friend: S cosilla is there some connection scheme to turn on the dash in bank? the bike is away from me can you help me ??? Thank you
Good Luck!
see if this one helps. Wish i had a power up to help you!
I want to try but I can not turn it on the bank I pass a picture of the connector on the board to see if someone can throw me a cable thanks
12v -1.2 amp....
Use gnd in capacitar use R omh proteccion. for sure you can lose it...
WINNER THE LOSER
This one 100% good.
For 850 km increase you could use pulse generator .
the problem is that now put the one that puts up the original mark 0 km: S now I do not know what may be happening: S
program eprom as 93lc46b...otherwise will not work
bad soldering
Direct on bike, no need to remove dash, acc on, pulse generator on vss and go >200km/h, drink few beers and job done.
