Results 1 to 9 of 9
    Nov 2017
    Default Pin Code PSA 96 434 935 80
    Hello.
    I have a psa BSI 96 434 935 80. I read eeprom 95040 because I want to know PinCode.
    Can you help me?
    Regards
    szengen's Avatar
    Jan 2017
    Poland
    bad read...
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  3. The Following User Says Thank You to szengen For This Useful Post:
    anjo008 (21st November, 2017)
    rob h's Avatar
    May 2011
    i dont think that this is even the correct eeprom.
    could be inside a nec processor.
    posting the ecu dump, might help.
  5. The Following User Says Thank You to rob h For This Useful Post:
  6. #4
    Nov 2017
    I have this
    I only have CarProg for reading and the BSI in my table. Iam not sure it is enough.
  7. #5
    rob h's Avatar
    May 2011
    Other side maybe?
  8. The Following 2 Users Say Thank You to rob h For This Useful Post:
    anjo008 (22nd November, 2017), szengen (22nd November, 2017)
  9. #6
    Nov 2017
    Also I have this:
    It have 2 NEC smd
  10. #7
    szengen's Avatar
    Jan 2017
    Poland
    Berlingo 2000-2002
    Xsara 2000-2002
    Peugeot
    Partner 2000-2002
    Original transponder PCF7936
    Allowed transponder PCF7936
    Data location uPD780949
    No. of keys 5
  11. The Following User Says Thank You to szengen For This Useful Post:
    anjo008 (25th November, 2017)
  12. #8
    rob h's Avatar
    May 2011
    In that case, pin to vin.
    Or upload ECU dump.
  13. The Following User Says Thank You to rob h For This Useful Post:
  14. #9
    Nov 2017
    ok. I will try
