    Aug 2015
    Exclamation Skoda Fabia 1.2 6V DTC Delete/erase
    Hy All!
    I have a Skoda Fabia 1.2 6V AWY.
    I changed 2 O2 sensors, CAT, Fuel Pump, Injectors but every time comes again 16804-P0420 and 16556-P0172 Dtc.
    someone can delete it?
    I would be very grateful!
    Best Regards: Kisvilli
    ohkarol's Avatar
    Oct 2010
    PL/UK
    Does your exhaust system is hermetic?
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
    Portugal
    hello.
    the problem you have is the catalyst is damaged, you just need a new one and the problem is solved.
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    This is OBD read, there is not DTC table in it.
    Read the flash with programmer...
    Regards!
  5. The Following User Says Thank You to bobolin4o For This Useful Post:
    pike (23rd November, 2017)
    Aug 2015
    Fec001's Avatar
    I have the same problem, I changed everything, even catalyst. Possible to switch off second lambda/cat?
