Results 1 to 15 of 25
    Oct 2013
    Default VAG 1.8T 20V tunning file problem
    ibiza flash read.bin.rarI have a stage 3 BJX engine (bigger turbo,camshafts and injectors). i have problem with boost pressure, i can't go higher than 0.8 bars. the tuner told me that he has setted up boost pressure to 1.2 bar but still can't go higher than 0.8 bar. can somebody check my file to confirm that my map is ok???? i need 1.2 bar boost pressure
    Andrei2015's Avatar
    Oct 2015
    you have any logs from car? you get any dtc or limp?
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    Oct 2013
    how to get logs? i have wow clone (wyrth) and i borrowed kess for a few days to read my map
    Oct 2014
    vagcom or me7 logger, probably you have a problem on your turbo or your n75,
  5. The Following User Says Thank You to ivanrojo For This Useful Post:
    maajkii (22nd November, 2017)
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    N75, DV, boost leak, underpressure.... a lot of parts to check
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    Oct 2013
    i have cheked everything. i even swaped all sensor form a car that works fine ,i cheked wiring. i'm almost sure that the problem is in ecu, can somebody confirm that the setup of my map is 1.2 bar? with vcds i read 0% duty cycle at 0.8 bar
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Hi, i mean file is good, i have same problem with car like you.... In my case is bad fabric blow off valve (spring have small pressure for valve, when you boosting, your boost leak back to filter...
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    Andrei2015's Avatar
    Oct 2015
    Default mod
    I think problem is in KFLDRL, please test this file
  10. #9
    Oct 2013
    i disconected turbo pressure tube from N75 and i got 1.7 bar!!!! so my turbo works fine
  11. #10
    Andrei2015's Avatar
    Oct 2015
    Quote Originally Posted by BRASTY View Post
    it is not turbo bro, is turbo control in sw
  12. The Following User Says Thank You to Andrei2015 For This Useful Post:
    BRASTY (22nd November, 2017)
  13. #11
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    to n75 come vacuum, no pressure. DONīT WOORY YOU LEARN IT
    If you have tested n75 from ok car, maybe is vacuum leak on your car
  14. #12
    Oct 2013
    thank you all for your advices. i will try andrei2015 map tomorrow
  15. #13
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Use thank button, under avatar,when you want thanked someone
  16. The Following User Says Thank You to Pyromaniak For This Useful Post:
  17. #14
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    how bar is your MAP sensor are you modified the MAP or not ???
  18. #15
    Aug 2012
    are u sure u have the correct connector from n75 on the n75 not the connector from n249
    your dtc from n75 is off :-)
    than why all rpm so high ??
    bad idle or what ?
    tell us what injectors ,hfm , inside ?
    i think deka 630 and s3 hfm
    what turbo is inside ?
    test how many boost u now have i have also enable n75 dtc
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  19. The Following User Says Thank You to icezero2010 For This Useful Post:
    BRASTY (23rd November, 2017)
