post file from obd and boot read
I had to to a dpf off on a bmw 116d with edc17(c06) 0281017551 1037507453 8512499. I didn't know if i could do it by obd or not so i tried. I found my model in the list, selected it and read data without prob. I modded my file and tried to write. It writed but, at the end, message from tool : write original file without shut down ignition. I did but had the same message and no solution at that time. I took the ECU and read it in boot mode without problems. I modded this file, writed it but car didn't start.
I suppose that my first attempt to write is the problem. my file was corrupted at that time, i think
Did someone have that kind of problem? how to solve?
thanks for help
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Zhed (23rd November, 2017)
thanks for answer
files read by obd and other in boot mode
thanks for help
Flash it by ISTA-P to solve the issue.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Zhed (24th November, 2017)
Thanks to all for your advice, but problem solved
just for your information.
i try to write the same file from another car but can't write this file, tprot data different and error message when flashing. I copy this data from my files to this one. After that, I can write the files but the car won't start.
This car was already tuned, i found the guy who did the job. He still had the ori file. I write this file and car start
Be carefull with your files, when i read new ecu for me, i try to search same read to compare my file with file from here (DK) I solve with this method many bad reads
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
