    Jul 2012
    Netherlands
    Default Mercedes W210 keys needed
    Hello everybody
    I'm working on mercedes W210 where key died (i think)
    EZS: 2105450008 based on 2xHC05 0D69J
    Files are attached
    Coul You please take a look if EZS is OK?
    If I compare with another one it looks OK, but...
    And generate 011 keys for one?
    My friend is generated for every CPU with SKC but these sets are not working.
    Best regards, Pete
    Mar 2015
    UA
    Write a dump to key NEC ?
    Jan 2013
    what type of key you use?
    Jul 2012
    Netherlands
    I'd like to use old type keys with 0G72G or 0F82B
    I have also NEC 051 keys but oryginal keys from the car are based on motorola HC05.
    metalik's Avatar
    Mar 2012
    hello all your key, test and report
  6. The Following User Says Thank You to metalik For This Useful Post:
    massiwe (24th November, 2017)
    Jul 2012
    Netherlands
    Yes it's working !!! The key 011 in old type HC05 key is OK
    051 not tested because I can use old customer keys.
    Thank You
