I think you swaped noCAN ecu with CAN one, or you have bad configuration in ecu (you must learn ecu with can clip)
Hi!
I have problem with Clio MK2 PH1, orginal ecu was IAW 5NR and it was damaged. I swapped ecu tu IAW 5NR2.C5 with immo off. Car starts and run fine, but I have a problem with A/C. The only dtc is DF145 - when it is present A/C is not working. When I clear this dtc A/C is running fine, but after ignition off and engine starts again dtc is present and A/C is not working. Maybe someone have solution for this? Here is my immo off 95160 dump.
thx
Kshin
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
The only learn in ECU are power steering and a/c conditioning. I`ve done that and nothing changed... What is exact name of funcion in CLIP to config nocan/can ecu?
Stock ECU was IAW 5NR.CI1 and it was swapped with IAW 5NR2.C5...
http://www.digital-kaos.co.uk/forums...-5NR2-C5/page4
look here, they are some virgin files, try to compare with your file
