Results 1 to 2 of 2
    Mar 2014
    Default i need inmo off GM corsa classic
    i m need inmo off ecu corsa classic 2009
    GM 94706578
    service :93338287
    ECM- F03
    FJlf
    FAMAR
    sergei5005's Avatar
    Nov 2012
    Bs As
    Default Hi friend ..see this
    Hi frieecu.nd. Im have kit ECU and antenna . You need change data in tw0 modules and programing one transponder. Or extract you pin code from antena TMS 370 and edit pin code in you new ECU. This pin code from you ECU data upload is 5174. Search this code in file 00A0. Extract you pin code from antenna and reeplace with you pin code in file 00A0.
