elprosys filter is tested solution ....i sugest elprosys!!!
What cas4 processor is in f01/02 2016 year ? And what is easiest way to change mileage only in dash?
Will canemu from codecard do since it says "CANEMU is tested on F01, F02 with 1L15Y processor......" but as i see this year can be cas4 with 5M48H ? I know smelecom emu can do it but i can't find it to buy in my country, only this from codecard and canemu china clone also...
edit: also is it maybe possible to fit emu in dashboard only?
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
doctore (24th November, 2017)
F01/F02 is from 08-2015 so is it a 15 or 16?
🔥Wacka Wacka 🔥
Yes it is series 7 f01 , and it is "older" model , maybe build late 2015 but first registration 2016.
Anyway i digged that it is possible to put emu only in dash on CAN circuit (TJA1042 or other TJAxxxx 8 pins IC) , and even china clone will work (it is not money issue, i just don't have anywhere in my country to buy other emu except ori canemu and china one). But if understood correctly i will have problem with eeprom in dashboard since 2015+ uses 35160WT and i will need emulator for that too... Also i don't know what tools can read 35160WT since it is needed to read eeprom ID in order to use 35160WT emulator.
Or anyone knows will this dash have 35160WT or older 160DQWQ eeprom ? tnx
In dash there is 35160 for models F01/F02, and in cas4 there is 9s12 processor. To make these machines, I use the MRPPad for reading and writing, work very well. For dash you need a emulator for 95160WT which you can buy from them or on web.
