Asifmehmmod1 (25th November, 2017)
this will be fine
i think
DPF/EGR-OFF , TUNE , FLAPS/SWIRL-OFF , DTC-OFF........
Unfortunatlly not well mate ... help ne guys
Sent from my SM-G935F using Tapatalk
i forced it now its turning ,, seems good key cut but somthing wrong with ignition cylinder thanks alot
its not so hard to push magic button
rola1971 (25th November, 2017)
Anyone could write cut sequence by mechanical number? number is 03020, blade hu92
If post helped, allways hit thank's
Evaldazj (19th September, 2018)
Both not wright, maybe 0302 would be good?
http://www.digital-kaos.co.uk/forums...=1#post3357916
I did reply to you in the other thread, this is from instacode
If i helped please press the thanks button
Hi please help to get mechanical or beating code for EWS3 I have VIN and file from EWS or how to get it when all keys are lost - door lock can't be removed without key? any solution
BMW_sb4fab.rar
Impossible to get keycode from VIN or EWS module. Yes, door lock cannot be stripped without key / without manupilating. This is 2 min lishi job to get keycode...
redliner (31st August, 2018)
Hello, need cut sequence by mechanical #2891.It is hu92
No thanks, Good luck with finding someone who helps you!
