Try this dump
But maybe other things in eepromare wrong, i calculate 31108 from your dump, but value for km looks crazy
Try this dump
Ok IŽll try it
Value from mileage looks crazy, I suppose this is the reason 999.999km is showed
I will test and report.
Does anyone have pinout for this dash???
Will be great to test it before
And if can I answer
What tool did you used??
Thanks anyway
EDIT: I found it ( comparing with your solution THANKS AGAIN)
15200km belongs to 03B6 in first two lines
0000: 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C
0010: 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C 01 5C
where the next bytes:
01 5C - is a mileage
Info showed in tachosoft seems correct even when seems different model.
Thanks anyway, your help has been important for me.
Learning every day.
If someone help
Ive erased and writed m35080 with r270 blue
IN menu m35080 selecting Type1 it recognises algo and mileage matches....
You can mod automatic with it...because algo is exactly the same.
Exactly as any other (vehicle) BMW 3/5/x5
Thanks again
Next time I will do this way
Thank you for this wonderful topic
