Page 1 of 32 12345611 ... LastLast
Results 1 to 15 of 474
    Default Interface picture collection.
    So after a reply to 'pvl' in an other topic. i thougt, let us make an interface picture topic.
    Keep it clean. Only pics and technical info.
    If you have questions start a topic with your questions and remarks, to avoid total 'kaos' in this topic.
    So lets all open up the interfaces we have at home. upload the pics and link them here.
    I will try to read out the chips later on and put the dumps also inthis topic...
    This is not MY topic. It would be great if You posted some pics also...
    Default Galletto 1260
    BIG
    BIG
    BIG
    BIG
    Galletto 1260 China clone from ebay.
    Default Vag tacho 1.7
    BIG
    BIG
    BIG
    BIG
    BIG
    BIG
    VAGTACHO 1.7 don't remember where it came from..
    Default Vag K+Can commander 2.5
    BIG
    BIG
    BIG
    BIG
    BIG
    BIG
    Vag K+CAN commander 2.5 with separate usb dongle.
    Never used it. was handed to my by a student.
    Don't have drivers or software. if you have it please pm me.
  5. The Following User Says Thank You to Robby&Bobby For This Useful Post:
    slawo1z (20th October, 2016)
    Default Galletto 1080
    BIG
    BIG
    BIG
    BIG
    Galletto 1080 tool. from autosenz. Verry bad build quality. Corrosion (rust) on the pcb, bad solding, all ic's are scratched...
    Default VAGCOM 409.1
    BIG
    BIG
    BIG
    BIG
    BIG
    Vag-com 409.1 i think we got it from autosenz. works great wit all 409.1 and older vagcom versions. Never tryed newer software.
    Default Vag-com 805
    BIG
    BIG
    BIG
    BIG
    BIG
    BIG
    Vagcom 805 from ebay china seller. Working good. solding quality inside is poor.
    Default KWP 2OOO +
    BIG
    BIG
    BIG
    KWP 2OOO + from autosenz. some sanded chips inside. Pcb glued in housing. some glue on ic and soldings. And wired bridges made on pcb.
  10. #9
    Default Tacho Pro
    BIG
    BIG
    BIG
    BIG
    BIG
    Old Tacho pro.
    Handed to me in Hong Kong 5 years ago. never used it...
  11. #10
    DK Veteran ivica's Avatar
    Apr 2009
    Does anyone have a Diga Consult pictures?
    Very,very thanks in advance
  12. #11
    Default ELM
    BIG
    ELM interface. came with some universal obdII software...
    All chips are sanded. no info on pcb. works with old vagcom, and most universal diagnose software. digimoto etc..
    Is serial so needs serial to usb for most laptops.
  13. #12
    pt
    vag tacho usb v3.01
  14. #13
    Default VAG K+ Commander V5.0 Full
    This is the K+ CAN Commander I purchased off ebay. The PCB is pretty good, once the latest FTDI driver files are downloaded the V1.4 software works fine on Vista Premium Edition but virus scanners do say there is a Trojan in the VWTester.exe file.
  15. #14
    DK Veteran rsibiza's Avatar
    Default VCDS 704
    Here are some pics inside and outside of my VCDS 704 worked for about 10 month without problems...after this perid it failed one time to connect to car,and after this time it never worked again.
    I reprogrammed the ATMEL 93C46 with dumps from here and the ATMEGA 162.
    When i test vcds i got message:
    Port status ok
    Interface found,not conected to car
    When i connect on car: interface not found!
  16. #15
    Default VCDS from Deal-Extreme
    Here the pics of my VCDS 805.1 from DX.
    Works since about 4 or 5 month without troubles.
    Hope will still continue working
