Page 2 of 32 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 474
  1. #16
    DK Veteran rsibiza's Avatar
    Default VCDS 812
    Here some Pics of 2 different VCDS 812 Interfaces.
    Noone of them worked not yet 2 times
    After setting date to januray it connectet to car for about 2 minutes,an after this nothing again.
    Tried out to fix it....no chance until now....still hoping.....
    There is an SO8 eprom,sandet and scratchet,dont know what it is,same like an 93xx,tried to read it with my labtool-48 but auti-ID wont work for 8 Pin....
    Has somebody an idea what can be thhis SO8????
    Will try to downgrade to 805...
  2. #17
    Default tachopro
    Quote Originally Posted by Robby&Bobby View Post
    BIG
    BIG
    BIG
    BIG
    BIG
    Old Tacho pro.
    Handed to me in Hong Kong 5 years ago. never used it...
    Got the same,never worked,bought an original one(well yet old) with original soft,the cloned one didn t work with this soft too.....
  3. #18
    pt
    Quote Originally Posted by rsibiza View Post
    i think 1 of the SO8 is an chinesse invention to flash the atmega and eeprom everytime they block, problem is they still block and this way making it hard to upgrade ore downgrade the interface because this SO8 (i think it is a pic) is intervering.
  4. #19
    Here are some pics inside and outside of my VCDS 704 worked for about 10 month without problems...after this perid it failed one time to connect to car,and after this time it never worked again.
    I reprogrammed the ATMEL 93C46 with dumps from here and the ATMEGA 162.
    When i test vcds i got message:
    Port status ok
    Interface found,not conected to car
    When i connect on car: interface not found!
    Attachment 6561
    Attachment 6562
    Attachment 6563
    For thoos who will look more i will upload the rar files of my pics,so pics can be displayd a bit greather.
  5. #20
    Default update includinng pic.rar
    Here the pics of my VCDS 805.1 from DX.
    Works since about 4 or 5 month without troubles.
    Hope will still continue working
    update with .rar
  6. The Following User Says Thank You to rsibiza For This Useful Post:
  7. #21
    Default update with .rar
    Now with .rar
  8. The Following User Says Thank You to rsibiza For This Useful Post:
  9. #22
    Default Universal Tacho 2008
    Here comes some pics of my Universal Tacho 2008.
    Until today got no problems with it...hope not to block
  10. #23
    Default and the last pics of universal tacho 2008
    The last picture and the .rar folder
  11. The Following User Says Thank You to rsibiza For This Useful Post:
    n599fbm (1st July, 2018)
  12. #24
    Default Digi-Tech Tablestation
    Here comes some Pics of my Digi-Tech Tablestation that i m using only as regulatet Power supply(works just great for this).
    I bought it on ebay as power supply.
    But i know that Digi-Tech is or was a chiptuner and the tablestation has an COM-Port and an Female OBD-II Port on Top,also is an other port in front of the tablestation which i even dont know what it could be.
    If someone had information or software for this tablestation i will be thankfull for informations.
  13. The Following 3 Users Say Thank You to rsibiza For This Useful Post:
    francsss (20th July, 2013), gameiruz (1st September, 2014), just4upal (8th May, 2016)
  14. #25
    Default MagPro2
    This interface i would open it because of guarantee....
    This Master just works great,really....have more drivers than MPPS,for same Price...just graet.
  15. The Following 3 Users Say Thank You to rsibiza For This Useful Post:
    gameiruz (1st September, 2014), gopelhu (12th November, 2014), just4upal (8th May, 2016)
  16. #26
    Default Auterra Dynoscan
    I Think the job of this interface is not really bad.
    I made some Dyno runs on a real Dyno (2 runs) and compared it to the Dyno Results made with my DynoScan:
    The Result is just awesome...5 to 7 HP of difference only (4 runs)
    If you purchased an original one,you can update it periodically...
    Make Diagnostics,make dyno files or just 1/4 mile registration...
    I like this Tool
  17. #27
    Default VAG Reset Tool
    This VAG Inspection Reset kit is just......
    An Inspection reset 01 no problem....but dont try to make an 15.000 20.000 km reset...never worked really
    But the idea isnt so bad
  18. #28
    Default now with pics
    Now including the pics
  19. #29
    Default K+Can Kommander Full 1.4
    My K+Can clone 1.4
    Works great since 3 years,pin code,immo,key learning...great
    But i could not install it onto 2. Laptop,have it working with that nice trojan in tester.exe on one laptop,so i have to tun off my virus scanner...
    On the 2. Laptop i got dog.....error something?????
    The soldering inside seem not so bad,no scratched or sandet eproms inside..
  20. The Following User Says Thank You to rsibiza For This Useful Post:
    estwood68 (31st August, 2020)
  21. #30
    Default VAG COM 311 clone from alphabid
    Dont know if poeple is always using some 311.2 soft from rosstech...this interface saved me so often works always
    (when my VCDS clones brick...)
