Page 12 of 32 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 474
  1. #166
    Jun 2010
    Slovakia
    Default VAG908 (VW, AUDI, SKODA, SEAT)
    This is my VAG908. I use it with my Audi A4 (2005), V6 2.5 TDI, 120 kW. Everything works fine, but after longer connection cable writes to the engine fault code:
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8EX5A572466 Mileage: 146350km/90937miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 8E0 907 401 AF
    Component: 2.5l V6 TDI G000SG 0050
    Coding: 02002
    Shop #: WSC 06314
    Part No: 00008059
    Component: 130 106KC318_1.V14944188584
    WAUZZZ8EX5A572466 AUX6Z0E0036456
    1 Fault Found:
    01318 - Control Module for Injection Pump (J399)
    34-00 - No Elaboration Available
    Readiness: 0 0 X X X
    I can't clear this code with the cable but it is possible to clear it with Autel Maxscan GS500 Code Reader. I noticed that the fault code dissapears in some minutes with ignition off or after disconnecting the battery. Same problem has also my local Audi service. After they update their software, everything is OK. I can't update.
  2. #167
    Top Poster + ka-pa-za's Avatar
    Jun 2010
    Quote Originally Posted by farkihome View Post
    69 75 76 77
    Coding: 02002
    Shop #: WSC 06314
    Part No: 00008059
    1 Fault Found:
    try 912 beta version for clone cable..
  3. #168
    Jun 2010
    Slovakia
    Quote Originally Posted by ka-pa-za View Post
    It will not kill my cable? Thanks.
  4. #169
    Jun 2009
    MPPS clone working with the latest original software.
    where can buy the interface?
  5. #170
    Jun 2010
    Slovakia
    Quote Originally Posted by dodgeripper View Post
    it's from eBay...
  6. #171
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Default CMD flasher orig.
    CMD flasher orig.with "glue off"
  7. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    gameiruz (1st September, 2014)
  8. #172
    Jul 2010
    Default AVDI interface
    Please link the foto of the 2 versions
  9. #173
    Sep 2009
    Poland
    - Secons SDI interface, little brother of Examiner Smart.
  10. #174
    Jun 2010
    it's from eBay...
    send me shop link to seller with mpps with latest software 3.0.2.31
  11. #175
    Moderator
    PremierD's Avatar
    Jun 2009
    Default UNIVERSAL UPA-USB... lol
    I have to thank Fallen ..for the idea just made it more compact.....
  12. The Following User Says Thank You to PremierD For This Useful Post:
  13. #176
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by PremierD View Post
    Lot of artists here around....likely.
  14. #177
    Aug 2010
    mars
    Default Not obd but heavy duty
    Sorry for the quality. My camera is fried. Phone pictures.
    The chips for the international are:
    74hc125n c7445ps (74hc/hct125 quad buffer/line driver 3state)
    sippex sp485ecp
    sipex sp232epc (sp232epc maybe max232 or like it?)
    pic16c620a-04/p (eprom-based 8-bit cmos microcontroller)
    lm293 (in a to-92 case . Maybe comparator or regulator)
    THe other board with only 3 chips is a Eaton Md-200. Its missing one chip at the connector end. This tool made itself under a tyre of a truck . Its made by autoxray. Maybe get a automotive auto xray 4000 to 6000 to compare and maybe make it for HD use.
    Chips are:
    Autoxray 530211 rev b 19402-001
    AM29lv008bt-90ed
    cy62256vnll-7
    Chip missing is a 8 pin chip.
    Ok anybody have heavy duty interface inside pics? Wondering if there is any clones for thise types of interfaces?
  15. #178
    Aug 2010
    Quote Originally Posted by bram380 View Post
    ELM327 USB tested with TouchScan 2.4.0:
    ELM327 chip = PIC18F2480
    The type numbers on the chips of my silver ELM are wiped out but I did find out:
    U1 78M05 051 Power Chip 12 to 5 V
    U4 PIC18F2480-1/SO Q8105SV ELM327 CHIP
    U9 FTDI FT232BL 807-1 USB -> Serial
  16. #179
    Jan 2010
    Minsk
    Default SUPER VAG 912 - Chinese Clone
    someone pictures of vag912 interface
  17. #180
    i need a photo of the smartbox X431 produced in 2009
