If it is IMMO3 you can get code from Engine control unit.
Or can use other tool, for example - VAG Tacho
hello I need the pin code of the instrument panel of a golf 4 1J920825c. is motometer.(kombi+wegfahrs.BOO V01)
I tried to read the eeprom with vag eeprom programer 1.19 and I could not be blocked, thank you very much for the help
If helped - "Thanks" and "Reputation" please
1J920825c Is Immo 2 . Read eeprom manually and post here , 24c02 chip.
it's immo 2. I do not have eeprom reader, nor desoldering
I only have vag com 311.2n and vag eeprom programer 1.19g with kkl cable.
Being the instrument panel motoneter gives me eeprom blocked.Help please
I gave you solution , there is no other way around .If you do not have tools then give job to someone who has it or invest in tools.
I thought I could have other alternatives but since I do not master these issues, I looked for solutions, given that the alternative is to drop the eeprom and download it when I have it.
Thanks for the inconvenience yugo45.
hello again, after a friend helped me I got the file of the eeprom,
motometer24c02.rar
and with the vag eeprom programer I discovered the pin code that is 8047
Help me please,with which program of the web I can encode this box with the echo of the car.
and if there is any program to put the real kilometers since this table has less than the broken one.
my friend, what exactly you want? Replace old broken dash within a new one? And old one has less km than new one?
If you have identical dashes both, you can simple change eeprom, from old to the new, and back to the car...
Otherwise, you need to have some tools (SMOK, VCDS...and similar) to read and calculate PIN code from both dashes, marry new dash to the car, change km and configuration, learn keys again...
rgds,
cuby
login is 8047
pls touch button
thanks for your time, I have the two pin codes, I have cable kkl with this cable can communicate with the VCDS or SMOK I have not used them I have the vag com 409.1 and 311.2n but without a license and it does not let me change the, and the kilometers either.
What cable do I need and where to get it for SMOK and VCDS?
a help please
try k+ can commander 1.4
HI.,ivassdown
you did not answer the question cubica1 what you want to do.
1) change a broken dash in the car,
2) adapt the keys,
3) change the mileage of the car
You must answer this question.
If you have 2 pins from 2 dashes (* 0 * 8047)
with vag kkl and VAG COM 311.2 Full or VCDS (Lite 1.2 Full) you can adapt a new dash,
add the keys. I do not speak perfect English but I still do not know what you want to do.
HI.,Mario6
I want to change a broken instrument panel (trying to repair it because it failed the speedometer, temperature, fuel, revolutions needles, erase the eprom 93C86 from a 1j0920825c vdo box) buy one from a 1j0920825c motometer (from this did not have the pin code and desolde the eeprom 24c02 by recommendation of YUGO 45 and the lei with vag eeprom programer to remove the pin code that is 8047) the pin code of the vdo is 1595.
After changing the table I was told that the keys have to be encoded in order to boot.
I read on the internet that you can change the kilometers and I wanted to adjust them since the car has 390831 and the box motometer has 301082, I do not know how to do it, I have kkl cable and with the vag com 311.2 without a license I can not change the frames, I do not have the complete VDCS lite where I can get it.
I think it's clear now, since my English is not very fluid either
Hey. It's bad that you did not buy VDO again. In VDO you could easily change the car's mileage using your VAG KKL interface and the VAG Eepromprogrammer 1.19g or VAG K can commander 1.4 / 2.5 programs. Maybe you can do it using VAG Tacho 3.01. Ask yugo45 what interface he read your eeprom and pin. However, try vag k can commander 1.4. (VAG KKL)
Ross Tech wiki
http://wiki.ross-tech.com/wiki/index.php/VW_Golf/Jetta/Bora_(1J/9M)_Immobilizer
When downloading, turn off the anti-virus
ivassdown (21st December, 2017)
HI, Mari6
I bought the motometer because it was the most economical option (I did not know that VDO were easier to program) and I read the eeprom by clicking it in a eeprom reading socket. You choose a .bin file and you read it with vag eeprom programer 1.9g.
I try vag k can comander and I will tell you how it goes.
thank you very much Mario6.
