Bentley Continental ECU 07C906018GM pin
Results 1 to 5 of 5
    Nov 2011
    Default Bentley Continental ECU 07C906018GM pin
    Hello frinds,
    can someone extract pin from engine ecu 95160 dump?
    RGDS
    Aleš
    Last edited by d5alilij; 30th November, 2017 at 09:11 AM. Reason: forgot to upload the file
    rob h's Avatar
    May 2011
    65535 pincode not 100% sure!
  3. The Following User Says Thank You to rob h For This Useful Post:
    d5alilij (4th December, 2017)
    Nov 2011
    Hello,
    I've got the same, but usualy starts with 0 or 1, I'll test today if I'll be able to connect with gateway...
    Thank you
    RGDS
    Aleš
    Nov 2011
    Hello,
    the pin is ok, does anyone know the power class for this engine type ECU? 6.0litre w12.
    rgds
  6. #5
    rob h's Avatar
    May 2011
    Do you have a tool at hand, like avdi vvdi2 fvdi svdi.
    You can get the power class by obd, if you have know pin and cs.
    CS can also be read by obd.
