Page 38 of 76 FirstFirst ... 28333435363738394041424348 ... LastLast
Results 556 to 570 of 1137
  1. #556
    Nov 2018
    thank you very very much. i kann work again...
  2. #557
    Nov 2018
    hi,
    my code is 203c-d001-0000-0015-d4c9-4e84. i'd be very grateful for a master password. thanks!
  3. #558
    Mar 2017
    Hi , help me fujitsu u904 pasword bios, 027D-0523-0083-4821-3922-8387 thanks.
  4. #559
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by novcat7 View Post
    hi,
    check code as it throws up error
  5. #560
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by sigla View Post
    for qwerty keyboard 0td4mjyq first is a zero
  6. #561
    Nov 2018
    Quote Originally Posted by smoggy View Post
    that is the code. I doublechecked several times. it's a lifebook n532. i have a script for 6x4 decimal codes but not for hexadecimal that's why i put my hope in you.
    what error do you get?
  7. #562
    smoggy's Avatar
    Apr 2009
    UK North East
    error invalid literal for int() with base 10: 'D0010
  8. #563
    Nov 2018
    oooohh, that's the same error i get :-( so the prog seems to accept hexadecimal only in the first four chars. what a tricky case!
  9. #564
    smoggy's Avatar
    Apr 2009
    UK North East
    that's correct
    hexadecimal in any other byte throws up error
    I have no experience with this, only code generator but as first post does it make any difference what 3 wrong codes are inputted
  10. #565
    Mar 2017
    BIG thanks .
  11. The Following User Says Thank You to sigla For This Useful Post:
    smoggy (17th November, 2018)
  12. #566
    Nov 2018
    For alle of you with same problem:
    Install this
    and for FSC 6x4 decimal digits like 8F16-1234-4321-1234-4321-1234 use this.
    Found here.
  13. #567
    Nov 2018
    Hi , help me fujitsu E734 pasword bios, 0270-0700-2129-1824-3765-2979 thanks.
  14. #568
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by x7Gam1ng View Post
    for qwerty keyboard try c2dozcm0 last is a zero
  15. #569
    Nov 2018
    thank you very much! best regards!!!!
  16. The Following User Says Thank You to x7Gam1ng For This Useful Post:
    smoggy (22nd November, 2018)
  17. #570
    Nov 2018
    Can someone help me?
    I followed the procedure, and I get this code:0222-3687-8121-5221-6062-8642
    Fujitsu s752
    Keyboard: QWERTZ
