Page 21 of 76 FirstFirst ... 1116171819202122232425263171 ... LastLast
Results 301 to 315 of 1137
  1. #301
    May 2018
    Quote Originally Posted by zhirong2534 View Post
    nedd password pls
    code is 0222-0588-8019-1201-5462-9011
    Try this: cwk3qiqy
  2. #302
    May 2018
    Quote Originally Posted by alkoxide View Post
    Can you guys help me to remove the bios password?
    Fujitsu Lifebook U904
    Hash code: 027D-0724-0075-8548-8992-8387
    Thanks in advance.
    Try this: 0pu4ugqj
  3. #303
    Feb 2018
    anyone tried the python code from http://dogber1.blogspot.com/2009/05/...red-bios.html?
    for the siemens-fujitsu 6x4 hash? its supposedly be able to find the 6x4 code, but all i get is errors even after tinkering with the code.
  4. #304
    Jan 2018
    Hi, could you help me with this hash for Fujitsu Stylistic Q736
    0299-0725-0127-9321-0906-1299
    Many Thanks
  5. #305
    May 2018
    Default I need Help Celsius H series
    Hello!
    I have the same issue. Can you tell me my password?
    0222-3698-6145-1631-4002-0163
    Thanks already in advance and regards,
    Günter
  6. #306
    May 2018
    hi
    need some help on fujitsu U772
    code is 0222-0668-4037-7931-4341-2258
  7. #307
    Dec 2017
    bro can you hel me please 0292-3765-0119-8729-6925-8290 thank you advence
  8. #308
    Dec 2017
    0292-3765-0119-8729-6925-8290 can you help me to find maser password please thank you advence
  9. #309
    teeaa's Avatar
    Dec 2017
    Finland
    Quote Originally Posted by Molina View Post
    Many Thanks
    Try sdd16b6w
    -ta-
  10. #310
    teeaa's Avatar
    Dec 2017
    Finland
    Quote Originally Posted by Hogan1 View Post
    Hello!
    Günter
    Try cftsvhqp
    -ta-
  11. The Following User Says Thank You to teeaa For This Useful Post:
    Hogan1 (18th May, 2018)
  12. #311
    teeaa's Avatar
    Dec 2017
    Finland
    Quote Originally Posted by Ateeque View Post
    hi
    Try o2xh89ut
    -ta-
  13. The Following User Says Thank You to teeaa For This Useful Post:
    Ateeque (21st May, 2018)
  14. #312
    teeaa's Avatar
    Dec 2017
    Finland
    Quote Originally Posted by Saymon2017 View Post
    Try o6xxuz2t
    -ta-
  15. #313
    May 2018
    FUJİTSU AH532 0F17-0697-0162-6358-5626-1155 TEŞEKKÜRLER
  16. #314
    May 2018
    I want to share with you how I learned how to change the end result of friends busy work.
    Firstly
    write down the codes on the incoming bios screen
    First password: 3hqgo3
    Second password: jqw534
    Third password: 0qww294e
    it will give you the bi code.
    sample :
    XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
    THIS CODE
    http://dogber1.blogspot.com.tr/2009/...ered-bios.html
    download this 6x4 file on this link (pwgen-fsi-6x4dec)
    To open the file:
    https://filehippo.com/download_python/4744/ download and install this program.
    Click and open pwgen-fsi-6x4dec and type in the code your computer gave to the cmd command that will open. )
  17. #315
    Jun 2018
    Quote Originally Posted by Talleresmalaga View Post
    Fujitsu stylistic Tablet Reset unlock BIOS password hash código 6x4
    Here you can get your master key, for Fujitsu-Siemens Decimal Digits 6X4
    during the next 2 weeks you can request your free master password, up to 25, 1 per registered member
    as?
    When asked for a password, enter these:
    You will receive a hash code with 6 blocks, each with four numbers,
    eg 12c4-4321-1234-4321-1234-4321
    Attachment 491524
    Attach this number to generate your master password
    Be careful, every time you speak the previous codes Hash and master password change
    regards
    Lifebook U904, oversecured by self (and bios pwd lost) ;-(
    Code: 027d-3951-4039-1621-0394-4995 (all digits apart from d)
    Any help appreciated. Thanks!
