Ford focus DM5T 14B321 LC
    Nov 2017
    Default Ford focus DM5T 14B321 LC
    Hi. I get a fault code 8005, airbag light flashing... Please help me to fix it .
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    I think you mean code B0005. That means Collapsible Steering Column Deployment Loop. There is a charge on the steering column under the dash that deploys with the drivers steering wheel airbag and or drivers seatbelt. You can replace the ignitor or the whole column.
  3. The Following User Says Thank You to repairmymodule For This Useful Post:
    jakis28 (4th December, 2017)
    megabits's Avatar
    May 2017
    South America
    Quote Originally Posted by jakis28 View Post
    Try...
    No pass...
    In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
    ATTENTION!!!
    Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
    Thank you!
    megabits.
    Aug 2014
    Also, you may want to scan the Occupant Control Module and make sure you clear any errors present. A code in the OSCM will cause the RCM to hold a non eraseable DTC and trigger airbag light
    Nov 2017
    Thanks all. Problem resolved, instead of the ignitor connect a resistance 3.3 ohm and airbag light stop flash.
    Jan 2018
    Default Damaged dump
    It think tahat my dump is damaged so i need cleared one...
