Results 1 to 4 of 4
    Jan 2017
    Default Ford Mondeo 2016 sync system
    Hi, i need pinout for ford sync module.
    HS7T-14G370-FFB.
    It has 54 pin connector.
    Can I connect this module on table?
    I found diagram but screen doesnt start.
    I only connect +12(1 pin) and GND(37,38pin)
  2. The Following User Says Thank You to srck For This Useful Post:
    asosa500 (4th August, 2018)
  3. #2
    Aug 2018
    Hello
    I have the same problem, and would be interested in find together the solution. Did you try using the can bus cable,
    Best regards
    Enviado desde mi iPhone utilizando Tapatalk
    Nov 2018
    Quote Originally Posted by srck View Post
    HS7T-14G370-FFB.
    Witam to wersja europejska 64 gb
    Nov 2018
    To modul europejski 64 gb czy inny proszę o info
