Results 1 to 5 of 5
    Mar 2016
    Default Hyundai H1 2006 starts only when scanner connected!
    The problem is car wont start, only starts when diagnostic tester is connected, when unplug tester engine dies. Fault code p0600 serial communication link fault. I suspect eeprom is corrupded or broken. Maybe someone have had same problem? Car is hyundai h1 2,5 diesel 74kw covec-f.(zexel ecu). Wiring and all is tested and good.
    Mar 2016
    Got this solved. Immo have to be turned off in engine ecu, othervise new immo box and keys needed and programmed.
    auto techniek's Avatar
    Mar 2017
    Can you tell us how it is solved?
  4. The Following User Says Thank You to auto techniek For This Useful Post:
    bonecrusher (14th December, 2017)
    Mar 2009
    Quote Originally Posted by auto techniek View Post
    xxxxxxxxx2
    Yes, I have the same problem p0600 on hyundai h1 and the car does not start, any help?
