Results 1 to 2 of 2
    rafal's Avatar
    UK - PL
    Default focus 2.0 tdci P0088
    hi all.
    i have problem with fault code p0088
    was done:
    1-new injectors
    2-new HP pump
    3-new pressure regulator valve
    4-ecu reflashed
    5-wiring checked
    after delete fault code car working ok about 10-20 minutes
    Dunker's Avatar
    Yorkshire
    I have had P0088 on a 2.0 TDCI Mondeo 2007. It was not high fuel pressure. It was the crank sensor wiring that had been previously trapped in the bell housing after a clutch change. All I can think is that the ECU defaults to high fuel rail pressure mode to kill the engine as soon as possible after it thinks it's lost sync. P0088 was the only code on the car and did the same as yours and came back after 15 mins or so.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  3. The Following User Says Thank You to Dunker For This Useful Post:
    rafal (9th December, 2017)
