Results 1 to 2 of 2
    makura's Avatar
    Default NEXIQ-RENAULT 12 PIN CABLE
    I want to make a diagnosis cable for Renault truck(12pin) and need help with db15 for nexiq and to which pin it will go on the 12pin head.
    i have 12 pin with obd2 female on the other end and i want to cut off the obd2 female and put db15 male plug.
    Member riggerout's Avatar
    Sep 2010
    Hello, try this schematic, you should connect the contacts
    J1708+ , J1708- , GND Battery- , POWER Battery+ .
    But what software will you use? with nexiq?
  3. The Following 3 Users Say Thank You to riggerout For This Useful Post:
    dupisa (29th December, 2017), makura (18th December, 2017), Roy Suryadwiananda (15th December, 2017)
