Use odis-e for update the dsg unit
Hello. I read my DSG with Kess v5.017. This is my software (attached)
HW: 02E927770AL
SW: v0695a0702ea__getriebe_DSG_Oh5a
Num.VIN:
Ver.SW:
Recambio:
Motor:
Ver.HW:
SW act.: 02E300053N 2207
Instalación: GSG DSG AG6 511
Now I want to update it to version 2238 (v0695a3802ec), I have the SGO file, but i need convert to bin. (attached).
And, this SGO to bin file can be flashed with kess?
Thank you.
dsg.expert can do it cost 10 dollars
DaniXDX (12th December, 2017)
Converted with SGO Expert. Here Update in .bin (attach).
figo1991 (31st January, 2018)
Post result, i think you can not update the ecu with kess
What is filesize from kess readout ?
Kess reads 1.46 mb, and the sgo to bin file update 704 kb. I simply copy the new file update over the 1.46 mb kess read (with offset). I try this weekend. I can see the new maps values ok, so i think that works.
OK let me know.
i have a sgo to bin from a X17 user and this file is 2048kb and my kess readout 1,5 mb
Kess will not flash this file.
Use ODIS or Vag Can Pro.
Updated DSG from version 2207 to 2238 with Kess. The update has been satisfactory, now the dsg works better and smoother, in addition to stage 2.
Hii, I have a question for you. After an oil leak from my mechatronic. They put a new mechatronic in my MK6 GTI DSG from 2009. No oil leaks and good shifts but I have a problem with my downshifts. When I'm doing a downshift, it's not revmatching and it takes longer than before... I've did a reseach and it must be something with the wrong software... Now I found many DSG SGO files but how can I know with one is the good one for my DSG?
I have this info from VCDS:
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 J HW: 02E 927 770 AE
Component: GSG DSG 082 1405
Revision: 04708020 Serial number: 00000802260639
Coding: 0000020
Shop #: WSC 01236 785 00200
VCID: 19392BEFD06C69D673D-804C
I think this is the file I need but I'm not sure,
v0698J0902ea__getriebe_DSG_mF8J_sw.sgo
I hope I hope u can help me!
Thankss
dear,
do you know how can i find dsg files for 02E300053N ?
using dsg reader tool
With MiniDSG reader you can use the file from post 4.
how did update ? i need
