Results 1 to 12 of 12
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Renault Twingo IAW 5NR.TI1 - immo off or emulator solution please help.
    Hi Folks,
    I would like to start this IAW 5NR.TI1 (T1 i think) ecu, with eeprom 95160 in hybrid area with small wires, looking for best way to bypass / off IMMO, has anybody could help with? Maybe there are some solution becouse i can't find. Please help.
    BR
    WinWoj's Avatar
    Jan 2012
    ECU City
    Could somebody confirm, that ECU : IAW 5NR.TI1 can be replaced for IAW 5NR.C2 ?? Looks the same, but some mates gad immo off solution for IAW 5NR2.C2 so that should be in standard PCB with known 95160 desolder-reprog method. But i'm not sure, if possible help someone.
    BR
    rafal's Avatar
    Jul 2010
    UK - PL
    Eprom 8pin - cut-off all wires
    and car start without immobilizer
    http://www.digital-kaos.co.uk/forums...from-5NR/page2
  4. The Following 4 Users Say Thank You to rafal For This Useful Post:
    Andreastech81 (18th December, 2019), louloupopar311 (16th January, 2018), MOBILTRONIC (3rd April, 2019), WinWoj (11th December, 2017)
    WinWoj's Avatar
    Jan 2012
    ECU City
    are you sure?? There are some issues before and nobody made immo off. I didn't founnd topic you linked, so big thanks. hope i did't damage this ecu...
  6. #5
    WinWoj's Avatar
    Jan 2012
    ECU City
    Hey guys, i cut that wires, and problem still remains... Immobilizer and ecu faulty dtc's... car didn't start, but sometimes immo lamp stops blinking and then engine start. one time for 100...
  7. #6
    WinWoj's Avatar
    Jan 2012
    ECU City
    There are this dtc present:
    DF022 Engine ECU pernament
    DF044 Immobilizer permanent
    Please help me...
  8. #7
    dadal's Avatar
    Aug 2015
    Quote Originally Posted by WinWoj View Post
    BR
    I replaced one of this ecu by 5nr2.t4 ( classic pcb )
  9. #8
    WinWoj's Avatar
    Jan 2012
    ECU City
    ok, but are you sure that you had hybrid and nr. c2 is classic?
  10. #9
    dadal's Avatar
    Aug 2015
    yes I m sure, it was an half hybrid ecu and replaced by classic pcb , T4 ,, not C2 but I think it can be swapped also by C2 ecu
  11. #10
    WinWoj's Avatar
    Jan 2012
    ECU City
    i found emulator, RENAULT CAN EMULATOR from SMOK, http://smok.com.pl/index.php?id_prod...duct&id_lang=2 but question is - would be working, when I cut that eeptom wires on hybrid part?? Because i'm confused, that rafal's solution doesn't work...
  12. #11
    WinWoj's Avatar
    Jan 2012
    ECU City
    ... maybe if hybrid eeprom wires are cutted, it is necessery to cut some another cables outside ECU? But if this ECU can be only emulated on CAN bus, like SMOK's manual shows, this rafal's cutting wires solution damaged my ECU and now I have to buy another ECU, which in classic PCB design are very expensive in my country...
  13. #12
    Dec 2017
    Hello, i have the same problem.
    What are you doing?
