Emulator must be for concrete immo system not "universal"...
in attachment manual for dedicated emulator not need solder any wires or add memory to emu all is on PCB this emulator, write PIN code to EMU and car work, any changes in flash or eeprom in PSA ECU to 2017 year
WinWoj (17th January, 2018)
hi avital could you tell me more about this emulator because it is not in English cant understand anything
Work with all ECU who have implemented communication immo system on can bus, only need store in 24C02 (on board emulator) PIN and set speed canbus 250 or 500kb/s.
For example ECU IAW6LP1 :
Hi folks again.
The file I thought is orginal seems to be isn't orginal, because when I flashed them and made immo off (manually and i'm not sure this method good) car didn't start... So i think the first attached file is from this car, named '2nd ecu' because check engine lights but immo dtc. So maybe is enough to make immo off this first file. Ori from 2.0 16V...
http://cloud.tapatalk.com/s/5a64ced6...sh_2nd_ECU.zip
anybody can help? DTC's still come back and 2nd dump immo off could solve...
Hello, please help me, i will code transponder for key, but i don't know which eeprom read to generate transponder dump. is there BSI eeprom or another immobox for this IAW 48P2.3T?
hi again sorry for late reply , I think you just uploaded a lot of files so now I need from you an ecu dump for 29f400 ( the one which will works )
and bsi eprom so the steps are
1) you will need to virgin the ecu
read the eprom from bsi so we could give you the pin
match key +ecu + bsi with lexia
WinWoj (5th February, 2018)
mstes, transponder should be precoded or something? i worry that I haven't empty one, only 7930 or 7935 but used from various cars, so could try to reprogram them using gambit, strange that bsi dump is not enough to create keys from bsi eeprom dump...
BSI dump already read.
1. Please help me to find PIN. Which software can find it?
2. Next step is transponder program. I bought new empty NXP 7935.
I have Gambit and ZedBul Mini, AD900. How to make it proper way?
3. Next step is virginize ECU. I also attached working, please help to make it.
Best Regards
Mates, I tried in Immokiller, ImmoserviceTool, PSA Calculator, PSA Dump to PIN, PSA ECU PIN... And didn't find any HC05B16 [1K20C] worked solution... Please help me to find that PIN...
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
WinWoj (7th February, 2018)
Hello mates. I tried two new ways to start this engin but without succes.
1st it was using 2nd ecu dump after immotool "immo off" solution, but cant start.
2nd was using orginal 2nd ecu dump with transponder generated using Effi Zed Bull, but can't start.
(generated from BSI HC05B16 dump)
The problem is, i can't proper install diagbox/lexia, always errors and regisetering fails...
Maybe somebody could help me and make virgine of that dump, i attached in post above, number #26...
Hello Folks, i found nd, that ecu IAW 48P2.3T is not for this ecu, because when i get another ori from dk, in fact i made immo off by immo tool, but also didn't turn check engine light on and no communication. so only IAW 48P2.38 which i have from customer seems to be good for this car, but immobilizer fault found. is anybody able to help with immo off because my pp200 haven't key learning function in BSI for this 206CC...
